Cisco CP-6901 dialplan configure on 3rd party PBX how to change interdigit timeout
Mauro Maganetti
Dear All,
I recently updated the firmware to: cmterm-6901_6911-sip.9-2-1-0 and configured the phone by using TFTP via xml files.
I created SEP<mac_address>.cnf.xml and dialplan.xml by using some sample files for Cisco 79xx IP phones. The phone is correctly registered to the PBX and it works fine.
The only problem is the interdigit timeout (default 10"). I can't change this value by using dialplan.xml. When I reboot the phone, the TFTP files are read and also the dialplan.xml, but nothing change.
Follow the dialplan.xml file:
<DIALTEMPLATE>
     <TEMPLATE MATCH="*" TIMEOUT="5"/>
</DIALTEMPLATE>
Someone can help me?
Regards.
Mauro
30 Replies 30
It's a very random behaviour because I have left my 6901 connected last 24 hours and the new DIALPLAN.XML provided by the TFTP server has not applied.
Any suggestion? I've also tried to upgrade and downgrade firmware but dialplan doesn't update.
