Cisco CUAC Java Requirement
Stuart C
Does anyone happen to know if there is a certain JAVA requirement for Attendant console to operate?  Version 11.0.1.
Jaime Valencia
Which flavor of AC?
java
if this helps, please rate
Hi Jamie,
This would be on Cisco Unified Attendant Console Advanced Server.
Stuart
It seems it's not called out in the docs as it's installed along with the CUACA server, or some of the other components that CUACA uses. So, whatever version was installed with CUACA, that is the one that is required by that specific version, and that's why the docs call out to disable Java auto-updates.
java
Hi Jamie,
Thanks for your response, that’s good enough for me.
Stuart
