11-16-2014 08:04 AM - edited 03-17-2019 12:57 AM
Dear all,
In process creating a Cisco UBE configuration between a Cisco UCM 10.5 and a Broadsoft IP PABX.
On the Broadsoft platform I have 10 (SIP) trunk licenses which I need to configure to be used on the UBE configuration. The provider which host the Broadsoft/Broadworks (19.x) platform only supports authenticated trunk users.
Any working sample configurations, normalizations, suggestions, pit falls are appreciated.
Looking forwards
Sijbren Beukenkamp
01-09-2017 01:14 PM
hey
were you able to make any headway with
we would like to remove DID/DOD assigned to users to save on number assignment
01-09-2017 03:48 PM
Chris, can you give an example of how you wnt this number manipulation to work and why?
cheers
01-09-2017 03:46 PM
use early offer and media flow through to keep Signalling simple.
what have you got so far?
there is no one size fits all for this, it all depends on how the far end is set up.
