Cisco CUCM 7841 line answer
Alex-Pr
Hi everyone,
On a multi-line phone, is there a way to have the line only answer line one when the handset is lifted?
As an example, if line 2 is ringing, and the handset is lifted, I want line 2 to keep ringing.  The only way that set can answer line 2 is by pressing the line 2 button.
I am working with CUCM version 12 and have cisco 7841 IP phones.
Thank you,
Alex.
On the phone configuration page (not the DN), there is a field "Always Use Prime Line". Set that to "On" to accomplish what you want.
That will set this on a per-phone basis. You can use the BAT bulk edit feature if you need to set this on a bunch of phones.
If you want to set this system-wide, there is a CallManager Service service parameter of the same name that you can set to On.
Maren
