Cisco CUCM Backup Port Change?
MehmetKaya
Cisco Unified Communication Manager 8.6.x we have. We back up system to remote SFTP server.
is it possible to change port from CUCM system.  ( for example we  want to use another port excep 22 port)  ?
No, you cannot change it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Chris Deren
Only sftp is supported for backups, if you can change the port on your sftp application then it might work.
Thank for your response Chris. But is there any where to change port on CUCM side. I want to change port on CUCM side especially.
java
java
Thanks to you Jaime and Chriss.
