Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco desktop agent logon ;
FujifilmFCB
Cisco Agent Desktop
The combination of user ID, password, and extension is invalid.
can anyone help me out here...
this user was renamed in the AD imported as every night happens , then stopped working in  uccx no more logon in cda
all the reply is very welcome
BR
Its working for me
https://supportforums.cisco.com/discussion/12391471/uccx-106-unable-login-agent
Anyways, a few things listed in the post that u can check / try
Finesse supports alphanumeric IDs and the special characters: hyphen (-), period (.), and underscore (_) in the user ID. No other special characters are supported. These characters should not be present at the beginning
or end of a ID.
Login to  cisco Desktop Administrator page > service configuration > synchronize directory service click synchronize if it is successful, try to login with the agent again.
Re-sync of CM Telephony User(s) (Subsystems/Cisco Unified CM Telephony/Data Synchronization)
Manish
Manish Gogna
You may try the suggestions in the following post
Manish
Manish
error 404 page has been removed
Its working for me
or end of a ID.
Manish
Chris Deren
In addition the login is case sensitive, so if your username defined in AD has uppercase/lowercase combination, make sure you enter it that way.
