Cisco E20 video ip phone,status:rejected
kaan dagli
I am trying to register e20(vTE4.1.1.273710) to CUCM(8.6.1)
Is auto-reg works correct with E20? Because i couldnt do.
And When i try to register with manuel-reg option, depent on this steps https://supportforums.cisco.com/message/3299316#3299316 ,
Device Information page looks like this
RegistrationRejected
IP Address10.200.80.133
Active Load IDUnknown
How can i register my e20 to Cucm?what is the reason of status and SIP id issues.
Kaan
Leonardo Santana
Hello
This discussion might help you!
https://supportforums.cisco.com/thread/2094064
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
I solved.The problem is the Dns fault. Registering rejected because of Cucm's host name didnt identified at DNS so E20 cant reach DNS correctly
I changed cucm's host name as Ip_adress of CCUM than tried to connect with Auto-register option Than everthing come back Green .)
So I can say for solution of rejected issue , Be sure proxy adress of E20 is configured correctly!!
thanks
Kaan
