IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6321 Views
  • 14 replies
Hi guys,i have a VG224 that is running IOS 12.4. and connecting via MGCP to the CUCM.unfortunaly it is in a rejected status on the CUCM and i remark that it is constantly downloading the configuration and swapping between the two CUCM's.after 30 seco...
abukuru95 by Level 3
  • 913 Views
  • 1 replies
Hi,Currently I have an issue with a SIP trunk by a provider that doesn't accept DTMF out-of-band, and is having trouble to accept RFC 2833 standard. Is there any other way to pass the tones "in-band" by ussing a different method?This question may sou...
HI all having an issue with some ATA 187 devices not registering.  I haver installed both software packs in the right order and on a test machine running 8.0.3 worked fine.  On site i have done the same but this is 8.0.2 CUMBE and the software loads ...
Hi All,Came in this morning and was advised some outbound calls were extremely crackly. It has been traced to all outbound FXO calls. A user dials, and the second the call is sent to the voice-port, even when you're hearing ringback - there is so muc...
