03-19-2015 07:13 AM - edited 03-17-2019 02:23 AM
I have an issue with a BRI interface on a CME 2901.
I have 2 MSN numbers on the BRI from the provider. One is 889553 and the other is 886602
I would like my extension 2050 to make outgoing calls only from the 889553 and extension 2048 to make outgoing calls only from 886602.
I can route incoming calls to the extensions successfully.
When somebody calls 889553, the call goes to 2050 and when 886602 the call goes to 2048.
I am interested in the opposite direction. Is it possible to be done??
Thank you
03-19-2015 07:45 AM
You could do this using COR Class Of Restriction. Assign 1 incoming corlist to the ephone-dn and the same corlist as outgoing to the dialpeer pointing to 1 of the BRI ports. Then repeat that with another corlist for the other ephone-dn and BRI port.
03-19-2015 08:03 AM
Thank you for your answer,
but the numbers come on the same BRI from the provider. On interface 0/0/0 on my router i have 3 available numbers (888822, 889553, 886602). Whenever a call is placed from any extension in my network, the number that the provider sends and is seen from the others is 888822.
I do not think it is possible to route calls through the MSN numbers using corlists.
Correct me if i am wrong.
I would like this:
2050 places a call --> call goes out through 889553 and the other participant of the call sees 889553 not 888822
2048 places a call --> call goes out through 886602 and the other participant of the call sees 886602 not 888822.
I have one BRI channel with 3 available numbers.
Thank you
03-19-2015 10:33 AM
You should check translation rules/profiles to modify the ANI as per your requirement.
03-19-2015 01:29 PM
Hello Vivek,
Thank you for your replay.
Can you be more specific with an example configuration
03-19-2015 10:09 PM
BRI is not in our region but I believe it's should work in same way as of PRI. Considering the same, you can use following translation rules;
voice translation-rule 1
#rule 1 /2050/ /889553/
#rule 2 /2048/ /886602/
voice translation-profile OUT_ANI
#translate calling 1
Attache the above translation profile to dial-peers as following;
#translation-profile calling OUT_ANI
Vivek
03-22-2015 12:46 PM
Thank you for the answer,
i know that on a PRI line it works fine (i have done it in the past).
I tried the above config but still no change..
03-22-2015 09:14 PM
You can get the output of 'debug isdn q.931' to verify the rules are applying correctly and desired ANI is going in setup message.
