11-16-2014 11:41 PM - edited 03-17-2019 12:57 AM
hy guys,
some useful discussion about cisco ios licensing. there is a setup of 3825 router. Now it is running as CME with CUE module with IOS 12.4.i want to integrate existing infrastructure with some new configuration and adding CUCM 10.x on BE6K but when i see the compatibility matrix of CUCM 10.x it shows 3800 series router will work but with 15.x IOS . can anyone explain the difference of 12.4 and 15.x.
i read somewhere that there is difference of licensing scheme of 12.4 and 15.x. what will happen to the 12.4 IOS licenses is that will work on 15.x or i have to purchase new IOS image of 15.x with features. what about universal image? Kindly share any useful link and document thank you.
Umer
11-17-2014 01:17 AM
Hi Umer,
For the differences , u can refer to Release notes of IOS 15.x
Toll Fraud Prevention was introduced in 15.x
Yes, with 15.x, u require licenses on ISRG2 to be activated through PAK. For ISRG1 , u do not require any licenses to be loaded on router.
What I suppose , since u are already running 12.x image with Voice feature set[already purchased], u can upgrade to 15.x as long as the router is under support contract.
you can watch the video
http://www.cisco.com/assets/prod/ios-nxos/ios_sw_releases_15/index.html
you can have evaluation UC/Security license for testing functionality on ISRG2 for 60 days on IOS 15.x while in ISR G1 routers, it was to be purchased for 12.x /15.x
you can refer the link
Let others also share ideas for more clarity.
regds,
aman
11-17-2014 02:42 AM
thank you very much for your quick response @aman
yes you are right that i have already running 12.x image with voice. actually i am trying to find if i will not change the IOS image which is 12.x.Is this fine or compatible with CUCM 10.x or i have to compulsory change to 15.x?
11-17-2014 03:02 AM
my suggestion would be to upgrade to 15.x to avoid any incompatibility/support issues.
we have upgraded GW to latest compatible version with CUCM.
regds,
aman
11-17-2014 03:42 AM
yes of course i will also prefer to change the IOS, But this is also a question that if i will not change the IOS as recommended by the Cisco. What would happen and what kind of issues i ll face, because i read the compatibility of CUCM 10.x but i haven't read anywhere that Cisco force us to change the IOS otherwise you will be facing these kinds of issues like some features will not working properly and some other issues
Umer
11-17-2014 07:49 AM
If you open a TAC, and the CSE believes the issue issue is due to a not compatible IOS release, he can ask you to upgrade before further troubleshooting is done. We do not test very single IOS with every single CUCM release, we also don't have any doc about what might fail with a certain combination
11-17-2014 09:47 PM
Hi Umer,
we were facing an issue of inbound/outbound calls not working between TDM[Siemens Exchange] and Cisco IP phone[CUCM 9.x]
Finally, we opened a tac case and came to know the GW IOS was the culprit. We upgraded IOS of GW and is working fine for than one year.
regds,
aman
11-17-2014 10:17 PM
thank you and agree with you Jaime according to Cisco recommendation we have to change the IOS. Its also difficult to test every single IOS with every single CUCM Release and certain combination of servers
Thank you aman that is what i want to know because there must be something exist in compatibility matrix because of recommendation by Cisco with new release of CUCM although CUCM have many features but basic functionality is calling. if there is any issue with inbound or outbound calling we have to move forward
Umer
11-24-2014 10:30 PM
there is lil bit confusion for me guys
as i mention that 12.4t ios is running on 3825 router. i see compatibility tool on this link
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
there is recommendation of ios 15.1.4M7 when i see the 3800 series router with 15.x ios there is some hardware difference. it must be 512/128.
512mb ram and 128mb flash. what i found the sku of 512mb ram MEM3800-512D=
but there is no 128mb flash sku
MEM3800-256CF=
there is only 256mb flash is it fine with 512mb ram ?
11-25-2014 12:15 AM
Hi Umer,
you check with Cisco AM on this but 128MB flash should be fine since all images with 512MB DRAM under 15.1.4M7 require 128MB Flash as per IOS download site.
regds,
aman
11-25-2014 02:51 AM
here i found the compatibility of cucm 10.5
there is recommendation of ios 15.1.4M7 when i see the 3800 series router with 15.x ios there is some hardware difference. it must be 512/128. on this link
https://software.cisco.com/
but there is no 128mb flash sku on ccw
which must be this one
MEM3800-128CF=
but i found only
MEM3800-256CF=
is there any suggestion or should i select the 256mb flash ?
11-25-2014 03:07 AM
there is no harm even if u install 256MB Flash.
regds,
aman
11-25-2014 05:24 AM
Thank you Aman
is there any service/support contract required from Cisco because it is already installed may be the customer's contract expires if there is any issue because i read that if the router is ISRG2 then there must be licenses otherwise not required
Umer
11-25-2014 07:37 PM
Hi Umer,
what best can be said is that if u are upgrading to higher IOS version say from 12 to 10 in same feature set , u do not require any contract .In case of any hardware issue, if u need to open tac case or do RMA , then, u need support contract for HW coverage.
same wud apply for ISR G2.
In ISRG2, if u are changing feature set like from voice shifting to security, then, u can get eval/temp license.
regds,
aman
