IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5959 Views
  • 14 replies
I have a 7962 with a 7914 attached.  The speed dials work, but the BLFs don't show the status of the in use line with a light.  On both the phone and the sidecar, the symbols are 4 little squares instead of phones like you would normally see.  I have...
MBGwho922 by Level 1
  • 2875 Views
  • 4 replies
Hello,    I am trying to modify the displayed CLI on my phones for international calls from the SIP provider we are using, they are sending international calls CLI in the format sip:+XXXXXXXXXXX@anonymous.invalid, I'd like to replace the "+" with "90...
cblaney by Level 1
  • 474 Views
  • 5 replies
Hi,Our company have 5 different department and each of those have separate reception.They requested to assign one single pstn number for each reception, with separate IVR and separate call handling.each 5 departments need only few options via IVR for...
frank3333 by Level 1
  • 458 Views
  • 8 replies
Hi everyone, On CUCM 10.0.1, I have a lot of speed dials as for example (end user called mom with external number +123456789), i would like when mom called anyone, it display the name mom instead of the number. My goal is to add plenty of speed dial ...
Hi,we wanted to install our official SSL certificates for the Callmanager, presence and Unity Connection.I had to regenerate the web-security from the console following the instructions.All values are in the correct order:orgunit orgname locality sta...
