CISCO IP 303 and Asterisk
luca.vasini
Community Member
I have a problem with Asterisk (13.0.15) and my two IP PHONE CISCO 303..
When I receive an external call on phone1, and I want to transfer it on phone2, the line falls ...
How can I solve it?
Luca
Dennis Mink
check the asterisk forums mate
Please remember to rate useful posts, by clicking on the stars below.
asterisk works well.. if I connect with 2 ip software installed on the PC, everything works fine..
the problem is the cisco phone..
Thanks and sorry for my bad english..
Luca
The SPA phones are handled in the SMB area, but as Dennis pointed out, general questions, and mixing different vendors are usually best handled in forums like voip.org
java
if this helps, please rate
thanks for your reply ,
I thought writing here because if I you use other hardware ( Grandstream ) everything works perfectly , while with my two cisco 303 when I transfer the call the line falls ...
then the problem is definitely some phone configuration ..
some idea?
thank you
