Cisco IP Commuinicator configuration with VMware View
shikamarunara
Level 4
Level 4
     My org is in the process ot deploying virtual desktops for end users and would like to use Cisco IP Communicator with it.  The VMware sessions use a different MAC address each time, so it doesn't appear that we will be able to configure the CIPC with it.  Instead, I would like to hardcode a MAC in the "Use this Device Name" field.  It works fine until I log out of the VMware session and log back in (in which case, the Device Name uses the new MAC address which is weird since I had hardcoded it - why would it change?)  Has anyone worked through this issue before?
ronpatel
Level 8
Level 8
Cisco IP Communicator is not supported in VMWare, Citrix, Terminal Services, Remote Desktop or other thin client environments.The software is not design to work in your environment.
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/8_5/english/release_notes/CIPC8x_RN.html
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
