Cisco IP Communicator 8.6 and VMware View
haouaswajih
Level 3
Level 3
Dear Networkers,
We do gave VMwarer view solution deployed. We are using CIPC v8.6 with CUCM v8.5
While accessing the client session with VMware view client and when using USB headseat (JABRA) with CIPC.
The issue is that when using such configuratio, we have a very bad quality with CIPC : micro-cutting in sound, bad quality..etc
I would like to know if CIPC 8.6 is supported for VMwaee View ?
Thanks inadvance.
Jaime Valencia
No, review the RNs for CIPC, it's not supported at all on any virtualized platform.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
