03-29-2013 07:01 AM - edited 03-16-2019 04:31 PM
Hi all,
Would you please give me a help about configuring SIP Trunk with a VoIP Provider like Pennytel on Cisco CME 9? I've searched around but no luck, thanks very much!
Solved! Go to Solution.
03-29-2013 11:32 AM
I did a Google search for "pennytel cisco config" and first result has working example config:
http://forums.whirlpool.net.au/archive/1965653
maybe it helps?
03-29-2013 11:16 AM
Thang,
You will need to speak to Pennytel and find out from them what you need to configure. Do you need to authenticate to their registrar servers? What IP address should you send your signalling traffic to? What sip port do they use? DO they require any other specific configurations...
In a normal/simple scenario a simple dial-peer pointing to their proxy server will do..So you need to get all the facts and we can hel with the config
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-29-2013 11:32 AM
maybe it helps?
