cisco ip communicator no Rcvr Packets
r.docuyanan
Hi anybody can help? my cisco ip communicator has no Rcvr Packets hence producing one way audio, My set-up is
CME 3.3 IP Communicator 2.0, my IP communicator is connected to the Head End device using VPN client 4.0.5D, attached is the statistics
s.jankowski
Level 4
Level 4
IP Address Auto-detection URL was not configured
Audio IP address settings can be viewed and configured from the Cisco IP Communicator interface by choosing: Right-click > Preferences > Audio > > Network... > Audio IP Address.
> -If you see that it is failing when calling ipphone locally check the port > that it is using (you can provide me with the traces for that one). -please once the problem is present run the sniifer traces on the PC and see do you see any packets coming, if you do move to the GW and check there as well where they are destinated to. Basically check where on the network they get lost or redirected.
jason-calbert_2
Level 3
Level 3
Have you checked to make sure all the ports are open for RTP. here is a link with the ports.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801a62b9.shtml
Please rate helpfull posts
Tony Huynh
Level 4
Level 4
Prior to CME 4.0, Ip communicator use with CME resulted in one way audio. CME 4.0 was the first version to support IPC. So you may want to upgrade to CME 4.0 to resolve the one way audio problem.
