Cisco IP Phone 3905 image downloading failure
I am using ISR4300 series router for CME.
3905 some phones showing image downloading....
Some phone image download failure
 Image is attached
Pls help me with suggestions
R0g22
How many phones are affected ? Do you see a 192.168.1.100 IP address in the error ? Is your phone getting an IP address from DHCP ?
7 Replies 7
R0g22
Tota we have 53 3905 model phone in our network. From 3 phones we are facing this issue.
3 set phone effected this issue
Debug the TFTP to see if they're getting the right image and if it's being transferred or not
java
if this helps, please rate
Please don't mark as solution yet.
Yeh its getting ip from dhcp
This solution doesn't really help the rest of us with this same problem.  What was done to fix the problem?
Thanks.
