03-05-2018 12:35 AM - edited 03-17-2019 12:20 PM
I have two IP Phones 6921 when I connect them to the network they show phone not registered or network unavailable and when I go to the network settings the phone suddenly take an IP and become registered and can make calls then become not registered again and so on.
I make factory reset to them but nothing change.
I want to know what is the problem !
03-05-2018 05:11 AM
03-07-2018 06:30 AM - edited 03-07-2018 06:34 AM
SIP or SCCP firmware for your 6921 IP phone?
Try to mirror your IP phone port with wireshark to check the deconnection cause.
Do U check the settings of the dhcp server?
I think the fact that you go to the network settting on your 6921 is not the reason why thé phone can be registered and had an IP@.
Stay on the main screen of your IP phone and check if it restart again even if registration is OK few seconds.
Check also the "status messages" on your IP phone.
