Resolved! protocol application invalid
Hi Friends,i am facing protocol application invalid erroe in cisco 7940 sip configuration ip phone. can any one help me to solve the issue.
Hello engineers!First of all, thank you for your help.I am not very familiarized with VoIP implementations or configurations, so I would like to know how can I transform or redirect an incoming call from a number of the PSTN to an internal directory ...
Hello We are planning to implement Cisco Jabber and our actual infrastructure with CUCM Version 10.5.2 works with pure IP, I mean, all servers are configured with IP Adress and not with the Host Names. Now, we have to change this and of course, the D...
Greetings, I want to connect siemence HI-path 4000 exchange to our data network via Cisco 3800 router. and hope to use the network to forward voice traffic to other end.we have both sides Cisco 3800 routers with VWIC2-2MFT-T1/E1 cards.Kindly ask how ...
Hi Folks, Need quick suggestion on the dtmf method usage for the below call follow: PSTN >> PRI >> VG >> MGCP >> CUCM >> SIP Trunk >> CUBE VG supports - OOB CUBE supports - RFC2833 DTMF on SIP Trunk configured as: No Preference: Will the trunk ut...
Hi, i have a newly setup CUCM 8.6 SIP trunk to CUBE. When a call comes in from PSTN-CUBE-UCM-Phone A and i then transfer this call to Phone B, the connected Party that is shown on Phone B is Phone B itself and not the original PSTN callers number...
Hi;From one day to another, the "License Usage Report" section began the following message: "The system is operating With An Insufficient number of licenses. If additional licenses to cover the shortage are not configured in your Enterprise License M...
Hi, I want to know what is the maximum distance at which we can install a analog phone from VG350. Like in Ethernet we have maximum 100 meter length of cable or maximum length of recommended UTP is 100m. In case of VG350 what is the maximum length o...
Hi, i need to test a background but before uploading it to cucm, i would like to test using this html code but i get webpage cannot be found. The phone is 8845 <HTML> <BODY> <FORM action="http://192.168.1.1/CGI/Execute" Method="POST"> <TEXTAREA NAME=...
Issue: White streak on Fax Page.Site Impacted 1 (Brisbane)Fax Device : Konica MFD connected to FXS port.Call Flow:PSTN--->ISR router (Working [10.103.12.10]/ Non Working [10.105.12.10])--->CUCM (TP--HP--HG(FXSPorts))-->VG (10.105.12.25)FXS Port--->M...
Hi everyone, I have a question.This weekend im going to upgrade an uccx v9.1 environement to 11.5(su2)What i need to is what is correct procedure to fullfill this?Also i know that when you upgrade to 11.5 there are some changements with CAD, because ...
Hello!I'm configuring a call forwarding from internal extension to the mobile number:ephone-dn 12 dual-line number 4021 no-reg primary label Test description 4021 name Test call-forward all 98967xxxxxx4There is no physical IP Phone for this DN, so ...
Hello everyone and thanks for the help i have a cisco call manager version 11.5 and an mgcp gateway with 4 fxo if all 4 fxo are in use i cant dial since all lines are in use any dialed number is not stored on the phone so if you hit redial it do...
Hi I have 2 clusters formed by these servers:Cluster 1: IP NETWORK 10.10.10.0/241 Publisher .11 Subscriber .21 Tftp Server .3Cluster 2: IP NETWORK 192.168.1.0/241 Publisher .11 Subscriber .21 Tftp Server .3I have configured a 7911 in cluster 2 with M...
Is Unified Border Element licensing enforced on the 2900 and 3900 ISRs? If so, what command can I use to determine how many sessions my VGs are licensed for? A show version just says I have the UC license.Thanks!Jeff
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
10 | |
7 | |
4 | |
4 | |
1 |
