06-24-2015 11:24 PM - edited 03-17-2019 03:28 AM
Hi Team,
Am facing an issue with Cisco 7921 IP phone when connecting to third party PoE switch ( Extreme ), the issue is phone is not even powering up.
Can anyone help me with the solution or the reason
Please note that the Phone boots normally when connecting to Cisco switches ( C3960) .
With Thanks & Regards,
Pradeep.
Solved! Go to Solution.
06-25-2015 03:10 AM
You may be running into the same issue discussed at the link below.
https://community.extremenetworks.com/extreme/topics/poe_switch_does_not_power_up_ip_phone
hope this helps
Please rate helpful posts
06-25-2015 03:10 AM
hope this helps
06-28-2015 11:18 AM
Thanks Charles
06-28-2015 12:12 PM
Your welcome.
