Cisco IP Phone 7960 Change Ringtone without CUCM
Trevor Janssen
Is there anyway to change the ringtone without the Cisco Unified Communications Manager? If so, how would I go about doing so? I am trying to add a ringtone called Batman.raw, and on top of that when I change the logo, it changes to a blank screen.
Jaime Valencia
Phones are hardcoded to find the .xml files for ringtones and backgrouds (if applicable) follow the regular instructions and place your files on a TFTP to try
java
if this helps, please rate
Jaime Valencia
java
can we do a WebEx meeting? I have put my files on a TFTP server but it doesn't want to get the files from the 1841 (that is the server).
I figured it out using wireshark and I got it to work fully.
