Cisco IP Phone 7965 - Call Forward – Auto off / cancel CFwdAll
moving_target
I'm using a 7965 at my desk with the softkey "CFwdALL" feature, and I was hoping there was some method of programming a set time for the feature to automatically turn off and return to normal.  My job forces me to leave my desk and work in the field with clients.  I would like to set up the phone to forward all calls to my cell phone when I’m away from my desk, then automatically return to normal at a set time of day, since it’s not practical (and sometimes impossible) to return to my desk to manually turn off CFwdAll.
Jaime Valencia
No, there are no associated timers, you need to either press the CFA button or do it via selfcare portal.
If you have Jabber with MRA, you can do it from there as well.
If you have a fixed schedule, you can configure ToD.
java
if this helps, please rate
Jaime Valencia
java
