Cisco IP Phone 8845, No Published Service
we have a published service set as directory that display OK on 8945 but not on 8845
the cucm is 10.5.2
8845 is on the latest FW and use the latest local
Any idea?
thanks
Jaime Valencia
You'll have to elaborate on exactly what it is you're doing here.
java
if this helps, please rate
Hello
in IP Phone Service, i ve a Phone Directory with a service url pointing to http://ciscophonedirectory.com/CiscoCorporateDirectory/CiscoDir4AD_Global-Start.asp
service category is web link
service type is directories
enabled
enterprise subscription set to true
i can see it on my 8945 by pressing the directory button but i cant see it on 8845 by pressing the directory button
i would like to see it on 8845 by pressing the directory button
thanks
my colleague found the issue.
he changed service category from web link to xml
