IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5824 Views
  • 14 replies
Hi, We have experienced multiple occasions wherein our trunkline is not reachable. And based on the isolations done, the call in numbers configured at the Cisco Unity Express are resulting to a busy tone when dialed. Temporary solution is to reload t...
fgramos01 by Level 1
  • 456 Views
  • 2 replies
Hello Community I got a problem with getting my regions to work properly, respectively to select the correct codec. I've built a small lab with 4 phones, two device pools and two regions to simulate a main and branch office. The settings are as foll...
Marlon by Level 1
  • 2672 Views
  • 17 replies
Dear Community, Am setting up inter-connectivity  between three branches. The main branch branch 1 which has E1 connection to PSTN ,branch 2 and branch 3.Only branch 1 and branch 2 have a call manager running CUCME, with MPLS connecting branch 1 and ...
isaaco001 by Level 3
  • 671 Views
  • 4 replies
Resolved! SPIAD cisco 2901
 Hi all.  I need help with how configuring voice mail and AA in my cisco spiad. If some one have one manual or any configuration for that.  I can see other configuration about CME, and  I don´t know if the configuration for cisco spiad is the same...
We just installed a PDVDM-32 and a VIC2-4FXO card into a 3845 router (2).  The FXO ports in one of the 3845 routers is registered and works fine.  However, in the second 3845 router, the FXO ports show as unknown.  The "sh ccm" command shows that the...
dtom by Level 1
  • 204 Views
  • 2 replies
