Cisco IP Phone 8851 Key Expansion Module Configuration Problem
imran.khan1111
Hello All.
We Already Using Cisco 8851 IP Phone with Key Extension Module which works fine, now we buy two new Cisco 8851 IP Phone with Key Extension Module and i am trying to configure the same like previous configuration done by another engineer but on the phone screen its shows Un provisioned message, if i do not use logout-profile with configuration so the phone only is working without extension.
here is the old Configuration. not all configuration but the mail lines.
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip handle-replaces
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server
  no silent-discard untrusted
  g729 annexb-all
voice register pool-type  8851
 xml-config maxNumCalls 4
 xml-config busyTrigger 2
 telnet-support
 gsm-support
 transport tcp
 num-lines 4
 addons 2
 description Cisco IP Phone 8851
 reference-pooltype 8961
voice register global
 mode  cme
 source-address 192.168.1.1 port 5060
 timeouts interdigit 3
 max-dn 200
 max-pool 110
 timezone 35
 tftp-path flash:
 create profile sync 124078985125320A
 camera
 video
voice register dn  104
 number 444
 name OPERATOR
 label OPERATOR
voice register pool  104
 logout-profile 1
 id mac 3820.5644.2164
 type 8851 addon 1 CKEM
 cor incoming internal-CALLS 1 701
 dtmf-relay rtp-nte
voice user-profile 104
 pin 12345
 user 444 password 444
 number 444 type normal
 speed-dial 1 300 label "Number_300" blf
 speed-dial 2 302 label "Number_302" blf
 speed-dial 3 303 label "MR_A_303" blf
 speed-dial 4 304 label "MR_B_304" blf
voice logout-profile 1
 pin 9999
 user ephone password 123456
 number 701 type normal
Amit23
Level 4
Level 4
Hello Imran,
please follow below link to configure module with 8851..
https://supportforums.cisco.com/discussion/12535011/how-configure-cisco-ip-phone-8800-key-expansion-module-kem-cisco-8851-call
Warm Regard's
Amit Sahrma
Hello Amit,
Thanks for the Reply as i mention before, the old 8851 with kem is working fine but now the new one is giving problem, i follow your link and apply but same message " UNPROVISIONED "
Picture of Phone is Attached
Imran
