IP Telephony and Phones
Labels
Publisher CM works fine, but when the Subscriber takes over there is no access to outside lines from the 2921 Voice Router. The Subscriber CM is syncing with the Publisher CM OK.  CM 8.5 2921 Voice Router at site. 2 PRI Lines, plus 5 pots lines in th...
I had the issue with "Unable to change tftp address in IP Communicator 8.6.1.0" 1> I tried selecting 'run as administrator' didn't appear to work for me at first.  Turns out I wasn't closing the application all the way before trying to run it again a...
S Sadiq by Level 1
  • 474 Views
  • 5 replies
I am running a couple of rear monitors off the output 3 connection on a MX800 Dual. I've read through the guides and it looks like I am able to add a panel to the Touch 10 that would allow for swapping of the monitor roles on those monitors but I hav...
Hi Team My customer will implement EMCC on CUCM clusters soon. I have a question about the EMCC with recording feature. Assumption: EMCC is enable on all CUCM cluster.1. User A (with EM profile A) login the phone A (with BIB feature) in CUCM A. One J...
davyeung by Cisco Employee
  • 459 Views
  • 1 replies
