Cisco IP Phone CFwdALL
sreekumara93
Hello All,
I have a doubt about the CFwdALL from the IP phone and from the call manager. If the end user set a forward all by using the soft key CFwdALL from the phone, will the same number display in the line page Forward All destination column?
Thanks in advance for your comments !
Sreekumar
Aseem Anand
Hi Sree,
Yes, you are correct. As soon as the user populates the CFDALL from the IP Phone it populates the CFADALL field on the DN in CUCM.
Aseem
(Please rate if useful)
Hello Aseem,
Thanks for your reply!
