Cisco Ip phone Incorrect Time Displayed
Dear All,
I have an issue of time displayed by Cisco Ip phone
Debug Display--------------------------------------------------------------------------------------------------
System version: 8.515900-4.1.
VMware Installation: 1 vCPU Intel(R) Xeon(R) CPU E5-2643 0 @ 3.30GHz, disk 1: 80Gbytes, 2304Mbytes RAM
13:10:18 9: Name=SEPF------95 Load= 9.3(1.1S) TFTP Error
 13:38:01 9: Name=SEPF------95 Load= 9.3(1.1S) TFTP Error
 13:38:01 22: Name=SEPF------095 Load= 9.3(1.1S) Last=Reset-Reset
 13:38:10 9: Name=SEPF------095 Load= 9.3(1.1S) TFTP Error
 13:39:20 9: Name=SEPF------095 Load= 9.3(1.1S) TFTP Error
TFTP active in subsriber
ntp accessible from subscriber/publisher too
time in pub/sub correct
Device Information--------------------------------------------------------------------------------------------------
UDI  phone
  Cisco Unified IP Phone 7965G, Global, Gig Ethernet, Color
  CP-7965G
  V11
  FCH1-------
Time  10:22:30
Time Zone  <-------------------------time zone is not displayed
Date  26/02/15
thanks to help us
7 Replies 7
Manish Gogna
The first thing you can try is to restart the TFTP service and then reset this phone and see if there is any change.
Manish
do it but doesn't work .
the issue occured even if we restart the hole call manager system but only with 4/300 ip phones
Is any specific phone model affected or all the phones? If only some phones are affected try deleting the ITL file on one of them and check if it works. If all of them are affected then provide the cucm and phone firmware version details as well.
Manish
different phone model affected.
can't access the security menu as it's grey even if i change the config in the phone configuration menu  and set it to
setting access>enabled
in the pub/sub admin gui
It seems that you have a secure cluster. If this is in production then you should open a TAC case to get this looked into as it could be related to certificates or CTL tokens.
Manish
The issue is more frequent with the
Cisco Unified IP Phone CP-7965G
App Load ID  jar45sccp.9-3-1TH2-5.sbn
Boot Load ID  tnp65.8-3-1-21a.bin
Version  9.3(1.1S)
Expansion Module 1
Expansion Module 2
Hardware Revision  12.0
Go to System > Enterprise Phone Configuration   solved the problem :)
