01-04-2024 12:09 PM
Cisco ip phone stuck on “configuring ip” and “unprovisioned” this was started to happen after configuring linksys E2500. Do I need to adjust DHCP settings on the router or port forwarding? Please assist.
01-04-2024 01:33 PM
Hello @lukeroy73
DHCP server is enabled on the Linksys ?
01-04-2024 08:25 PM
Yes it is enabled
01-04-2024 02:15 PM
Is DHCP Option 150 enabled?
Is there a Voice VLAN available?
01-04-2024 08:26 PM - edited 01-04-2024 08:26 PM
150 enabled
where can i see voice vlan?
01-05-2024 03:42 AM - edited 01-05-2024 04:21 AM
Dump question: Why don't you ask the questions related to Linksys devices in the forum of Linksys?
Just because the device you connect to the Linksys is a Cisco device, you ask the question in a Cisco forum?
The forum here only can provide general configuration considerations, but the information of how to actually configure the linksys device should be searched in the linksys docs, website, forums, ...
01-04-2024 11:43 PM
It should be on VLAN Management menu.
Anyway.. did you define any VLAN on Linksys?
If you connect a PC with the same cable of the phone, do you receive an IP Address?
On which Call Control system should the phone register to? (CUCM , CME)
Please let me know
Carlo
