Cisco IP Phone
Daniov1
Hi ,
My customer wants to have the following:
When client hold "#" on IP Phone pad the Phone automatically place a call to some number(without press "dial" just hold the button "#" for a few seconds).
Thanks.
Leo Laohoo
It is called "speed dial".
Why hold the "#" key? Client only wants one number? What happens if the client wants more than one number?
The client want to hold "#" for emergency calls.
There is translation pattern configured on CUCM for "#" pattern which translate "#" to the Emergency number.
The client doesn't use "#" button for something else.
George Sotiropoulos
As Leo described below, you should consider creating a Speed-Dial, what type of Phone Device does your costumer use?
Hope the above helps,
gsotirop
Jaime Valencia
That cannot be done, if they're on hook, you need to press dial to place a call, just leaving a button pressed does nothing. If they're off hook, the translation pattern will do the job.
java
if this helps, please rate
