Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco IPT End User Training -VoIPTrainer on the phone
valiegenus
Dears,
can we apply this  feature voip trainer service on my IPT system , i notified it on youTube :http://www.youtube.com/watch?v=a4OlvMS4PGs
i have call manager, 5.x and ip phone 7940/1/70/42
could you please send me a guide for configuring it and on which palteforms of callmanager and ip phones models can be done?
thanks.
This is for Cisco but it's not sold or supported by Cisco. Yes, this you need to buy from the vendor and they should provide all the integration guides.
The link you posted already tells you who you should be reaching for this and their contact info after the 2 minute mark.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
You should be asking this to whoever sells the product, from the link you posted:
4What Interactive, the leading provider of on-demand interactive  training and support for Cisco IP phones, today announced the  VoIPTrainer can now be accessed directly from the Services button on  Cisco IP phones. Previously, users accessed VoIPTrainer via a web  browser on www.voiptrainer.com, or via a link on a corporate intranet  site.
java
java
thanks javalenc,
do you mean that this service isn't for cisco and i must purchase the service from the vendor and then integrate it with my ipt system?
please advice
regards.
java
java
Rob Huffman
Hi Val,
Just to add a note here to the good info from Java (+5)
These "free" Tutorials from Cisco seemed to solve the training issue for us. We
looked into the IPT Trainer series and found that the series from Cisco was more
than sufficient
Cisco IP Phone 7940G eLearning Tutorial
http://www.cisco.com/E-Learning/bulk/public/celc/7940_Tutorial/index.html
Cisco Unified IP Phone 7941G/7941G-GE eLearning Tutorial
http://www.cisco.com/comm/applications/CCNP/qlm/7941/index.htm
Cisco IP Phone 7970 Series eLearning Tutorial
http://www.cisco.com/assets/cdc_content_elements/flash/voice/7970_tutorial/index.htm
Cheers!
Rob
