Cisco ISR FXO Connected to Telco Linksys SPA8000 FXS
Carl Messer
I currently have an issue connecting my FXO point into a telco phone line (Linksys SPA8000 box), whereby any incoming or outgoing calls are immediatly disconnected.
An incoming call will ring and once answered the call will immediately disconnect.
There is another telco box (no branding) providing additional analogue lines which work fine.
Does anyone know if I need any particular pinouts with an FXS going into an FXO? I am currently using a straight through cable.
Below is an output of my debug vpm signal:
Feb 21 08:20:49.571: htsp_process_event: [0/1/0, S_OPEN_PEND, E_HTSP_GO_UP]
Feb 21 08:20:49.683: htsp_process_event: [0/1/0, FXOLS_NULL, E_HTSP_INIT]fxols_n        ull_init
Feb 21 08:20:49.683: [0/1/0] set signal state = 0xC timestamp = 0
Feb 21 08:20:49.683: htsp_process_event: [0/1/0, FXOLS_INIT, E_HTSP_INSERVE]fxol        s_init_inserve
Feb 21 08:20:49.683: [0/1/0] set signal state = 0x4 timestamp = 0
Feb 21 08:20:49.683: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Feb 21 08:20:49.739: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0110]
Feb 21 08:20:49.739: fxols_line_reversal_clid_wait. On_hook line reversal detect        ed possibily due to crossed cable
Feb 21 08:21:00.495: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fx        ols_onhook_ringing
Feb 21 08:21:00.499: htsp_timer - 125 msec
Feb 21 08:21:00.627: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVE        NT_TIMER]fxols_wait_ring_min_timer
Feb 21 08:21:00.627: htsp_timer - 10000 msec
Feb 21 08:21:00.627: htsp_timer3 - 5600 msec
Feb 21 08:21:00.627: [0/1/0] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
Feb 21 08:21:00.627: htsp_start_caller_id_rx create dsp_stream_manager
Feb 21 08:21:00.627: [0/1/0] htsp_dsm_create_success  returns 1
Feb 21 08:21:02.587: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
Feb 21 08:21:02.587: fxols_ringing_not
Feb 21 08:21:02.587: htsp_timer_stop
Feb 21 08:21:02.587: htsp_timer - 10000 msec
Feb 21 08:21:03.555: [0/1/0] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATUR        E_SM_CALLERID_RX
Feb 21 08:21:03.555: htsp_process_event: [0/1/0, FXOLS_RINGING, E_HTSP_CALLERID_        RX_DONE]
Feb 21 08:21:03.555: htsp_timer_stop
Feb 21 08:21:03.555: htsp_timer_stop3
Feb 21 08:21:03.555: [0/1/0] htsp_stop_caller_id_rx. message length 19htsp_setup        _ind
Feb 21 08:21:03.555: [0/1/0] get_fxo_caller_id:Caller ID received. Message type=        128 length=19 checksum=27
Feb 21 08:21:03.559: [0/1/0] Caller ID String 80 10 01 08 30 31 30 32 30 32 34 3        9 04 01 50 08 01 50 27
Feb 21 08:21:03.559: [0/1/0] get_fxo_caller_id calling num= calling name= callin        g time=01/02 02:49 number blocked name blocked
Feb 21 08:21:03.559: fxols_callerid_done: call being answered
Feb 21 08:21:03.563: [0/1/0] htsp_dsm_close_done
Feb 21 08:21:03.563: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SE        TUP_ACK]
Feb 21 08:21:03.563: fxols_wait_setup_ack:
Feb 21 08:21:03.563: htsp_timer - 6000 msec
Feb 21 08:21:03.563: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server        type radius (UNKNOWN)
Feb 21 08:21:03.567: htsp_timer_stop3
Feb 21 08:21:03.567: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_PROCEE        DING]fxols_offhook_prochtsp_setup_req
Feb 21 08:21:03.571:  Orig called num:107
Feb 21 08:21:03.571: htsp_process_event: [50/0/7.1, EFXS_ONHOOK, E_HTSP_SETUP_RE        Q]efxs_onhook_setup
Feb 21 08:21:03.571: htsp_ephone_start_caller_id_tx calling num= calling name =        called num=107 orig called num=
Feb 21 08:21:03.571: [50/0/7.1] set signal state = 0x0 timestamp = 0
Feb 21 08:21:03.571: efxs_onhook_setup: local target is available
htsp_alerthtsp_alert_notify
Feb 21 08:21:03.579: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_ALERT]        fxols_offhook_alert
Feb 21 08:21:06.483: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_000        0]fxols_proceed_ring
Feb 21 08:21:06.483: htsp_timer_stop
Feb 21 08:21:06.547: htsp_process_event: [50/0/7.1, EFXS_WAIT_OFFHOOK, E_DSP_SIG        _1100]efxs_waitoff_offhook
Feb 21 08:21:06.547: [50/0/7.1] set signal state = 0x4 timestamp = 0 htsp_dial
Feb 21 08:21:06.547: htsp_process_event: [50/0/7.1, EFXS_CONNECT, E_DSP_DIALING_        DONE]
Feb 21 08:21:06.547: htsp_call_bridged invoked
Feb 21 08:21:06.551: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNEC        T]fxols_offhook_connect
Feb 21 08:21:06.551: [0/1/0] set signal state = 0xC timestamp = 0
Feb 21 08:21:06.551: htsp_timer_stop
Feb 21 08:21:06.551: htsp_process_event: [50/0/7.1, EFXS_CONNECT, E_HTSP_VOICE_C        UT_THROUGH]efxs_connect_cutthru
Feb 21 08:21:06.551: [50/0/7.1] set signal state = 0x7 timestamp = 0
Feb 21 08:21:06.551: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT        _THROUGH]fxols_connect_proc_voice
Feb 21 08:21:06.751: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_0100]f        xols_normal_battery
Feb 21 08:21:06.751: htsp_timer_stop2
Feb 21 08:21:06.903: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SIG_0110]f        xols_rvs_battery
Feb 21 08:21:06.903: htsp_timer_stop2
Feb 21 08:21:13.863: htsp_process_event: [50/0/7.1, EFXS_CONNECT, E_DSP_SIG_0100        ]efxs_offhook_onhook
Feb 21 08:21:13.863: htsp_timer - 10 msec
Feb 21 08:21:13.875: htsp_process_event: [50/0/7.1, EFXS_CONNECT, E_HTSP_EVENT_T        IMER]efxs_connect_wait_release_req
Feb 21 08:21:13.875: htsp_timer_stop
Feb 21 08:21:13.875: htsp_timer_stop3
Feb 21 08:21:13.875: htsp_process_event: [50/0/7.1, EFXS_WAIT_RELEASE_REQ, E_HTS        P_RELEASE_REQ]efxs_waitrls_req_rlshtsp_report_onhook_sig
Feb 21 08:21:13.887: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_RELEASE_R        EQ]fxols_offhook_release
Feb 21 08:21:13.891: htsp_timer_stop
Feb 21 08:21:13.891: htsp_timer_stop2
Feb 21 08:21:13.891: htsp_timer_stop3
Feb 21 08:21:13.891: [0/1/0] set signal state = 0x4 timestamp = 0
Feb 21 08:21:13.891: htsp_timer - 2000 msec
Feb 21 08:21:14.163: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110        ]
Feb 21 08:21:15.891: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_T        IMER]fxols_guard_out_timeout
Feb 21 08:21:15.891: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Feb 21 08:20:42.075: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_IF_OOS]hts        pm_mgt_state
Feb 21 08:20:42.075: htsp_timer_stop
Feb 21 08:20:42.075: htsp_timer_stop2
Feb 21 08:20:42.075: htsp_timer_stop3
Feb 21 08:20:42.075: htsp_timer_stop_mlpp
Feb 21 08:20:42.075: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, ch        anged state to Administrative Shutdown
Feb 21 08:20:42.075: htsp_process_event: [0/1/0, S_OPEN_PEND, E_DSP_INTERFACE_IN        FO]
Feb 21 08:20:42.247: htsp_process_event: [0/1/0, S_DOWN, E_DSP_SIG_0110]
Feb 21 08:20:49.567: htsp_process_event: [0/1/0, S_DOWN, E_HTSP_IF_INSERVICE]
Feb 21 08:20:49.567: htsp_process_event: [0/1/0, S_OPEN_PEND, E_DSP_INTERFACE_IN        FO]
Feb 21 08:20:49.571: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, ch        anged state to up
Feb 21 08:20:49.571: Foreign Exchange Office 0/1/0 rx_signal_map:
F F F F
5 F F F
F F F F
F F F F
Feb 21 08:20:49.571: [0/1/0] set signal state = 0x4 timestamp = 0
Feb 21 08:20:49.571: Foreign Exchange Office 0/1/0 tx_signal_map:
0 4 4 4
4 4 6 4
C C C C
C C C C
0 Replies 0
