Hi All,we have deployed CBE6K. For redundency we are building a BOMwhich includes UCS C220 server. do we need an integrator or something like that for settingup the redundent CUCM & CUC servers with already installed once. Best RegardsKennedy
Hello Team, We have 7.1(3) CM located at Sydney, and around 16 Cisco 6921 IP Phones which were located at Mumbai registered to CM at Australia over MPLS. We have dedicated 2 mbps car for voice traffic configured at our WAN Router. All phones register...
I am trying to create a voice translation rule for incoming call. I want to translate incoming number from my sip provider: anything that begin with an "+" , then forward the last 4 digits to call manager.I am already using incoming called number ....
Hi All,There are lot of discussions on the forum regarding the "caller ID not displaying" problem. One of the post suggested to enable "caller-id alerting dsp-pre-allocate" with which i am now able to see the calling party number in the debug vpm si...
We have users who wish to have a common phonebook available on multiple 7925 phone sets
hi all,We use the cisco 6921 and several other types of phones for example 7975.Next weekend the phones have to display 1 hour later.Funny thing is that only the 6921 is displaying the "summer time" now already (instead of next weekend)It has 9.3.3 f...
I would like to know where I need to go to stop outside callers from bypassing reception. Can I change the code or just turn it off so noone can bypass reception.Using Cisco BE6k Cisco Unity Connection version: 9.1.2.10000-10Thanks,Mike
Hi,i have activat the after hour in cme 9.1, i can login and logout with the 6921 but the 7962 and 7965 i have the LOGIN softkey inactive.what can i do to activate this login softkey??thanks
Hi guys,would it be possible to allow sip users to register over the sip trunk on the Call Manager? or is this method not allowed?Thanks.Best regards
I've successfully installed a Unity Connection 9.0 cluster on UCS C220-MS3 platforms and subsequently upgraded it to 9.1.I created a port group and I'm trying to add 48 ports to that port group. When I do this I get the following message:"Port limit ...
Hi !Does anyone know if this issue has ben solved in CUCM V10 ?Thank you,Regards,Christian.
Dear Team,Sometime I am facing issue with VM mailbox while importing to unity server , when i assign VM proofile to extension in device profile and trying to import in unity connection server it does not display and in that case i have to create ...
Hi there Our publisher reboot itself for some reason around 8:56am and it came back successful around 9am. We would like to know what happen. Can someone help to check the logs and give some idea.I have collect Event View logs for reference. CheersFe...
We have uploaded a new MOH file on the CUCM server. The new file is played when user is placed on HOLD. However the file does not get played from the start, it plays from anywhere in the middle, each time from a different place, any idea? MOH is unic...
Hello all,Many of our customers are running on CUCM ver8 & ver9.We are planning to push them to upgrade Unified products on ver 10. Can any body share the key differences between ver9 & ver10 ?what technical or non-technical points we should explain...
Subject | Author | Posted |
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
6 | |
5 | |
2 | |
2 | |
1 |
