Cisco Jabber for Blackberry 10.
Sergey Lubenkov
Hi Everyone,
I know cisco doesn't support jabber for Blackberry any more and last supported version was for CUCM 8.6.
But I am still wondering if somebody was able to run it on CUCM 9.1.2 ???
Thank you,
Jaime Valencia
The BB client was IM only, it had nothing to do with CUCM, voice services were all thru BB servers:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cumc/cisco_jabber/blackberry/1_0/Cisco_Jabber_IM_for_BlackBerry_1_0_Administrator_Guide.pdf
java
if this helps, please rate
I don't really care about voice. Is it possible to make IM work?
No way to answer that, there was no testing whatsoever beyond the releases mentioned in the doc, you would need to try it out and see.
If not, you can try any standard XMPP client.
java
OK, thanks....I'll try.
