11-01-2016 05:57 AM - edited 03-17-2019 08:32 AM
Has any encountered issues with the iphone jabber client not able to search active directory for users. Everything else works and all I get is invalid credentials.
11-01-2016 06:18 AM
What version of Jabber, version of CUCM, and are you using UDS or EDI/BDI for directory?
11-01-2016 06:38 AM
Hi Chris
Jabber for iphone version 11.72.247543 and CUCM version 10.5.2.1000-5
We have LDAP setup for the general user authentication which works fine. I have configured the TCT device for LDAP and have pointed it at our global catalog server (think you need to do this) and set the LDAP search path and user etc (copied from main LDAP config). I read something about mapping attributes on AD schema but not sure if this is right. LDAP is not secure connection.
11-01-2016 06:40 AM
JAbber logs in fine and you can dial extensions, but cannot search the active directory. It states I have invalid credentials. I have ensured the username entered is in UPN format to.
