Cisco Jabber Limit Exceeded for Attempted Calls error
Michael Murman
and end user had an error message pop up when trying to dial out using the Cisco Jabber, 12.8.2, - Limit Exceeded for Attempted Calls.  The number of calls you made exceeds the limit set by the administrator.  Log in again to resolve the issue.
We don't limit our recruiters on the number of calls they can make. Any ideas?
Jaime Valencia
Review these two parameters and adjust as required in your deployment:
TelephonyProtocolRateLimit and TelephonyProtocolTimeLimit
java
if this helps, please rate
I don't am not familiar with that setting, where is is located?  On the Jabber client on the desktop? Or in CUCM?
They're Jabber parameters.
java
