08-04-2021 12:04 AM
Hello everyone,
I have noticed in Cisco Jabber, phone services on the app it shows the CUCM server address, which is against the company policy, how this issue can be sorted and is there anyway to use OTP services to login?
Solved! Go to Solution.
08-06-2021 01:38 AM
For this you’d need to use MRA in Expressway. Depending on the size of the deployment you might need to use multiple in a cluster. Read the deployment guide for MRA for the details on this.
08-04-2021 12:19 AM
08-05-2021 12:12 PM
I have informed the concerned team, will update if this resolves the issue.
08-05-2021 11:28 PM
Is it the fact that you see the actual IP address of your CMs that is the issue at hand or is it that you’d want to hide any information pertaining to the CMs from your end users that is the issue at hand?
08-06-2021 12:20 AM
want to hide the information of CM
08-06-2021 01:38 AM
