cisco jabber
hi dears , did the cisco router 2851 supported cisco jabber android phone ?
Manish Gogna
Hi Abraheem,
2851 only supports CME versions upto 8.x. Jabber support is only available in 9.x and higher versions so it will not work. Please check the following for details
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
Manish
jabritt
The 2800 series is almost end of life and the newest ios release available for it will not support jabber. If you mean registering it to the gateway.
(15.1(4) M10)
Manish Gogna
Hi Abraheem,
Manish
