cisco mcs 7800 drivers
iboboewfs
I am looking for the CD to boot my Cisco MCS 7800.
is there someone outhere who know a link where I could the ISO for to reinstall the Server ?
it allso called the smart aray disk for HP .
SIncerly
Chris Deren
What server?  You did not specify what you want to install, which application, what version, etc?
Either way it would be illegal for someone to provide it to you if you are not entitled to it, and if you are you should contact Cisco TAC or contact your Cisco re-seller to provide it.
HTH,
Chris
I have my cisco account and can download ios.
I have an old cisco MCS 7800 that I am setting up for my LAB.
it have a old windows 2000 server that I want to upgrate to 2003 server.
plus I will be installing the CUCM 6 or 7
my problem now is to reinstall the OS and I believe I would need the smart ray Disk to make this happen
clarify me if I am wrong.
CUCM 7/8 does not run on Windows, it is an appliance which includes embaded Linux OS, so when you install CUCM it installs the OS with it.  In order to obtain bootable media you need to place an order with Cisco or if you are eligible place an upgrade order, that is the only official way of getting bootable CUCM media.
Of cource there are unofficial paths such as contacting your local Cisco SE and see if they can help out, etc.
HTH, please rata all usful posts!
Chris
