Cisco Media Sense Calling and Called party Identification
Vishal Parekh
I am using Media Sense in my infra and looking after exactly how to identify Incoming and outgoing calls which got recorded.
When i see the recording in my search and play list, I am unable to identify who has called in and who has called out.
Calling and Called party identification is not much clear from the Media Sense Search & Play Option.
Here,I am attaching the Screen shot of normal call recording in which i have manually mark the incoming and outgoing call.
But, i want to know how to identify the calling & Called party by directly looking at the recording.
Thanks in Advance.
Deepak Rawat
Lower number XRefci will always be for Calling Party and Higher Number XRefci will be for Called Party. In your Outside to Inside example, calling party is 9042305068 and called party is 316. In Inside to Outside example, 316 is calling party and 2305068 is the Called Party.
Deepak
Deepak Rawat
Deepak
Vishal Parekh
Thank you, I had also mark the same but was not confirmed. Also, If you have any other way out to check the same then please let me know.
Thank you once again for your time.
Vishal
