Cisco Media Sense Server: Hardware Support
cristian.munoz
Level 4
Level 4
Hi Guys
I need information about of Cisco Media Sense Hardware Support, I can´t found the server supported.
Please, I need help.
TIA
Cristian.
Ratheesh Kumar
Hi there
Please find the below link
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-mediasense.html
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Dear Rath
I have already seen this document but it indicates that no server is compatible
I have been there, anyhow i checked the following document :
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/115/Design_Guide/CUMS_BK_MC36D963_00_mediasense-srnd_115/CUMS_BK_MC36D963_00_mediasense-srnd_10-5_chapter_0111.html#CUMS_RF_S3551E6E_00
Server Models Supported
MediaSense can only be deployed on a VMware hypervisor, which must be running on the following:
Cisco B-series or C-series server with Fiber Channel-attached SAN storage (for at least the first two disks) or with directly attached hard disk drives
A UCS-E module running within a Cisco ISR-G2 router
Other servers (subject to the stated minimum performance) (see Compatibility matrix below for versions and model numbers).
All the information you need is in that document..
Hope this is what you are looking for
