IP Telephony and Phones
Labels
Hi ,   We have Cisco 7841 and Cisco 7945 phones in our CUCM 11.5 environment. When I press f.e. 0 on the 7945 I get a list with all the recent call's I already called starting with a 0. When I press 0 on the 7841 it does not show my recent called lis...
Hi,In a CUCMv9, how i can activate a call forward (all, busy, no anwser...) with Third-party SIP Device or with a analog device connected to a fxs?I want to activate a call forward like a Alcatel or Aastra PBX with a code.For exemple, i pick up the p...
Hi Guys,   I have a c2911 router with a UCS-E140S-M2/K9 module inserted. I want to power the module OFF and remove it from the router. I can power the module OFF via the CIMC port, but can the module be removed from the c2911 router without powering ...
tdudas by Level 1
  • 794 Views
  • 1 replies
Hi,   One of the user's deskphone 7940 is not receiving any external calls, phone is not at all ringing but calling party can hear the ringback tone.  I matched the directory number settings with the working phone and also tried replacing the IP phon...
we have a 4300 serie router , and a sip trunk to a service provider, outgoing calls are working perfectly but not incoming; having try to "debug ccsip messages" for an incoming call, there is no output at all, while it works for an outgoing call, we ...
soraya by Level 1
  • 5284 Views
  • 24 replies
hi  i have Cisco phones at office , my problem is i received a conference call we conference code by email as invitation  i dial the international number (Holland for example) normally and then the answer machine requesting me to put the conference c...
I have a cisco 2911 voice router set up for sip trunk to provider.    I am running this behind a nat device and trying to get sip profile to rewrite the private ip to the public ip.    I have set this up with applying the sip profile to my dial peer....
mspdog22 by Level 1
  • 1593 Views
  • 3 replies
