Cisco MGCP DTMF issue
hi,
when i am calling outside, i dont hear any ring tone, meaning no phone ringing is coming, its just blank
hence i am not able to know if the person phone is ringing or not?
Can some1 help me how to troubleshoot this issue?
Thank,
8 Replies 8
Ayodeji Okanlawon
Nitesh..Why DTMF heading? Can you send us the sh run of your gateway. Can you describe your call flow..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
card type e1 0 3
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
isdn switch-type primary-net5
voice-card 0
no dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface FastEthernet0/1
no ip address
no ip unreachables
ip nat inside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1.10
description SUB_INT_SUPPORT
encapsulation dot1Q 10
ip address X.X.150.1 255.255.255.0
ip flow ingress
ip nat inside
ip policy route-map AIRTEL_2
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/3/0:15
ccm-manager redundant-host X.X.150.8
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server X.X.150.7
ccm-manager config
mgcp
mgcp call-agent X.X.150.7 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1.10
mgcp bind media source-interface FastEthernet0/1.10
mgcp profile default
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions hardware 10
dial-peer voice 1 pots
service mgcpapp
port 0/3/0:15
I have the following devices:
1. Cisco 2811 - with IOS 12.4 with latest IOS
2. Cisco CUCM 8.6
3. Integration between 2811 and CUCM 8.6 MGCP.
When i am calling outside i dont hear the phone ringing, its just a blank.. a slience..
I want to hear the phone or call ring when it goes out..
that is the problem...
Do you get ringback on inbound calls? Can you do a test call and send the output of debug isdn q931
Yes when I call my extension from my mobile I get a ringing tone but not vice versa
Sent from Cisco Technical Support Android App
Send the debug isdn q931
have you tried to add the command voice alert send-recv at ur gateway
it was routing linked to my one way audio..
after that worked.. it was working properly...
