06-10-2013 11:37 PM - edited 03-16-2019 05:47 PM
Hi Guys,
Once I dial into any conference, I am unable to enter the digits if I am prompted to.
E.g I dial Cisco TAC support, and I am told to press 1 to record a message. I press the 1 but there is no response.
I have two voice routers connected to each other.
On one of the voice routers (Router 1), there is an E1 line terminated on it. The config is as below:
Router 1:
dial-peer voice 4 pots
description TELKOM DIALPEER
destination-pattern 9.T
incoming called-number 9T
direct-inward-dial
port 0/3/0:15
The connection between the two router is as below:
Router 1 (IP address 10.10.10.1):
dial-peer voice 1 voip
description INTERNAL_CATALYST_VOIP
destination-pattern .00
session target ipv4:192.168.10.1
dtmf-relay rtp-nte
codec g711ulaw
Router 2: (IP address 192.168.10.1)
dial-peer voice 3 voip
description PSTN_GATEWAY
session target ipv4:10.10.10.1
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
What could be issue. I have tried all avariants of dtmf i.e. h245-signal h245-alphanumeric cisco-rtp and even combined them variously but to no avail.
I've also added the command: voice rtp send-recv.
WHAT COULD BE THE ISSUE?
06-12-2013 01:55 PM
Sounds like you need MTP (Media termination point) to carry the DTMF from your keypad through to the service to commit a selection
06-12-2013 10:11 PM
How do I Configure the MTP?
06-12-2013 10:47 PM
Hi Andrew,
Refer the below link.
http://rsccievoice.wordpress.com/2012/06/18/media-termination-point-mtp/
06-13-2013 02:24 AM
Let me take a look.
Thanks.
06-13-2013 02:42 AM
Andrew before you configure an MTP you should understand your call flow..
Your DTMF config are wrong. You shoudlnt use rtp-nte on a h323 dial-peer, cisco doesnt support that. It is supported on a sip dial-peer..
Can you describe your call flow and waht phone models are you using?
IP phone--CUCM---h323--gateway--E1?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-13-2013 04:30 AM
The call flow is as below:
Cisco IP Phone ---------->Cisco Call Manager EXPRESS---------->Cisco Call Manager EXPRESS(E1 is here)
06-13-2013 04:39 AM
You need to configure an inbound dial-peer on the second cucm express. Ensure you have dtmf-relay h245-alphanumeric on it..
Can you attach the config for both ccme
06-13-2013 11:54 AM
Here is the config of the router with the E1
no aaa new-model
network-clock-participate wic 3
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice-card 0
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice translation-rule 1
rule 1 /^4296/ //
rule 2 /^730142/ //
voice translation-profile INCOMING-E1
translate called 1
controller E1 0/3/0
pri-group timeslots 1-31
controller E1 0/3/1
framing NO-CRC4
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.252
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip route 192.168.10.0 255.255.255.0 10.10.10.2
ip route 192.168.20.0 255.255.255.0 10.10.10.2
ip route 192.168.30.0 255.255.255.0 10.10.10.2
ip http server
no ip http secure-server
disable-eadi
control-plane
voice-port 0/3/0:15
translation-profile incoming INCOMING-E1
voice-port 0/3/1:15
sccp local FastEthernet0/1
sccp ccm 192.168.10.1 identifier 1 priority 1 version 5.0.1
sccp
sccp ccm group 1
bind interface FastEthernet0/1
associate ccm 1 priority 1
associate profile 1 register conf_dsp_1
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
associate application SCCP
shutdown
codec g711ulaw
direct-inward-dial
port 0/3/0:15
Here is the config of the Router where the IP Pjones connect to:
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname CMS_VG
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 3000000
aaa session-id common
clock timezone EAT 3 0
network-clock-participate wic 1
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
voice iec syslog
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 5
max-pool 5
dialplan-pattern 1 9.T extension-length 3
dialplan-pattern 2 8.T extension-length 3
tftp-path flash:
create profile sync 0001884471822119
voice register dn 1
number 100
name ATA
label 100
mwi
voice register dn 2
number 101
name ATA
label 101
mwi
voice register pool 1
id mac C062.6B62.A3C7
type ATA-187
number 1 dn 1
number 2 dn 2
codec g711ulaw
rule 1 /^730142/ //
rule 2 /^4296/ //
translate called 1
license udi pid CISCO2911/K9 sn FCZ161370N2
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description LINK_TO_CAT3560_SWITCH
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description CMS_VG INTERFACE FOR VOICE VLAN
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
description CMS_VG INTERFACE FOR DATA VLAN
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface SM1/0
description "Unity Express Module"
ip unnumbered GigabitEthernet0/0.10
ip virtual-reassembly in
service-module ip address 192.168.10.2 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 192.168.10.1
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http path flash:GUI
ip route 0.0.0.0 0.0.0.0 192.168.20.254
ip route 192.168.10.2 255.255.255.255 SM1/0
ip route 192.168.30.3 255.255.255.255 192.168.10.254
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0.10
sccp ccm 192.168.10.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.10
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 7
codec g711ulaw
sip-ua
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on *1 mute-off *2
sdspfarm units 5
sdspfarm tag 1 conf_dsp_1
no privacy
conference hardware
no auto-reg-ephone
max-ephones 50
max-dn 100
ip source-address 192.168.10.1 port 2000
no service directed-pickup
system message Catalyst Management Services
cnf-file location flash:
load 7915-12 B015-1-0-4.SBN
load 7915-24 B015-1-0-4.SBN
load ata ATA187.9-2-3-1.loads
time-zone 31
date-format dd-mm-yy
voicemail 500
mwi relay
max-conferences 8 gain -6
moh "music-on-hold.au"
web admin system name cmsadmin password admin
dn-webedit
transfer-system full-consult
transfer-pattern 9.T
transfer-pattern ...
ephone-template 1
softkeys hold Resume Newcall
softkeys idle Redial Newcall Cfwdall Dnd
softkeys seized Endcall Meetme
softkeys alerting Callback Endcall
softkeys connected Hold Trnsfer Endcall Confrn
softkeys ringing Answer Dnd
ephone-template 2
softkeys idle Redial Newcall Cfwdall Dnd Pickup
softkeys connected Hold Endcall Trnsfer Confrn
after-hours exempt
type 7942
ephone-template 3
ephone-dn 1 dual-line
number 000
ephone-dn 2 dual-line
number 001
ephone-dn 3 dual-line
number 002
ephone-dn 4 dual-line
number 003
ephone-dn 5 dual-line
number 004
ephone-dn 6 dual-line
number 005
pickup-group 10
ephone 1
mac-address C8F9.F9D6.0259
ephone-template 1
after-hours exempt
type 7962 addon 1 7915-24
button 1:1 7m2 8m3 9m4
button 10m5 11m6 12m7 13m8
button 14m9 15m10 16m11 17m15
button 18m16 19m13 20m21 21m14
button 22m20
ephone 2
mac-address A418.7529.8391
ephone-template 2
after-hours exempt
type 7942
button 1:2
ephone 3
mac-address A418.758A.10F2
ephone-template 2
after-hours exempt
type 7942
button 1:3
ephone 4
mac-address A418.758A.2F76
ephone-template 2
after-hours exempt
type 7942
button 1:4
ephone 5
mac-address A418.7529.8386
ephone-template 2
after-hours exempt
type 7942
button 1:5
ephone 6
mac-address A418.7529.8441
ephone-template 2
after-hours exempt
type 7942
06-13-2013 01:52 PM
On the router with the E1 configure this..
incoming called number .
no vad
Test again
06-13-2013 09:58 PM
Thanks. Let me try.
