10-20-2017 11:33 PM - edited 03-17-2019 11:26 AM
We have cisco CUCM, we have deployed jabber at our premises and it is working fine. the problem is that now that certifcate which deployed on Expressway E is now expire and i have other requirement too such as MRA i wanted to deploy one cisco 8845 IP phone at remote location and i wanted to register that on my CUCM.
The requirement for that is Expressway E certificate and CA root certificate, correct if i am wrong. That needs to be signed from internet authority (publicly signed). i want both services to be run jabber as well as MRA, can u guys please tell me which type do i need to be signed from CA. for example
single signed certificate
extended certificate
wildcard certificate
etc.
10-21-2017 03:14 AM
So just to cover this, yes, you HAVE to sign the Expressway-E in a trusted public certificate authority, otherwise the phone will never register via MRA.
Another thing you must know, is that the phones are having built-in public Root CA certificates, so if you'll sign your certificate with a certificate authority which isn't included in root certificate list the phone contains, the phone also will not register via MRA.
So... attaching you the CA Trust list document that includes all the CA's. Just verify with this list that your CA is included there, if so, it's safe to sign the certificate.
By the way, regarding the type of the certificate. Expressway-E does not support wildcard certificates, it should be a single certificate for a specific common name (of the EXPR-E), BUT this certificate MUST include SAN support (Subject Alternate Name), because when you create the CSR you'll see it adds the main domain of the server to the SAN (I still don't understand why they're doing it, but it is not possible to remove it), which means the certificate is more expensive compared to a certificate without SAN.
Hope it helped ;)
10-21-2017 06:29 AM - edited 10-21-2017 06:31 AM
Hi Slavik
Thanks for your reply, we doing this because the other location only has internet access where we will deploy the Cisco 8845 IP phone and we were strictly told that VPN configuration for this is not allowed. due to that, we come with MRA solution.
moreover, I wanted to know is that phone already consists CA/root certificate and if yes then I do not to generate CA certificate for the phone. I need some assistance from your end as this is my first implementation with Cisco CUCM.
Thanks in advance.
10-21-2017 06:36 AM
11-10-2017 12:39 AM
Thanks, It works for me.
