Bookmark
Subscribe
1734
Cisco phone 7841 not registering
Tazio4436
Hello everyone,
I have some Cisco 7841 phones which cannot register.
In CUCM the load information is sip78xx.11-5-1-18 but the 7841 software version shows sip78xx.11-1-1MSR2-1.loads.
I tried a firmware upgrade to sip78xx.11-5-1-18 but it did not work.
Any help will be much appreciated.
Tazio
2 Accepted Solutions
Jaime Valencia
The phone is loaded with 3PCC/MPP FW which is not supported with CUCM, that's why it doesn't register.
If you want to register it with CUCM you would need to migrate from 3PCC/MPP to Enterprise FW, all details are at upgrade.cisco.com, there may be associated costs as you need a migration license.
java
if this helps, please rate
Thank you very much for your help.
Jaime Valencia
java
