Updating Phones via Bulk Administration
LeeWay
I have to update more than 1000 phones, specifically a single speed-dial button items. I know i have to use bulk administration for this, how can i go about doing that?
Thank you in advance!
Jaime Valencia
Configure a test phone that would look like a real phone, export it via BAT to see how the fields are formatted and then adjust as necessary to test with a single phone and understand how the procedure works. Then export a few actual phones to see how they're formatted and compare to your tests to understand exactly which fields would need to be updated.
java
if this helps, please rate
After finding and configuring the headers/fields of each requirement, i got a CSV ready. Now, how do i deploy this out to the existing phones across the property?
Thank you again,
