10-23-2018 08:48 AM - edited 03-17-2019 01:38 PM
Hi All,
Is it possible/supported to update the firmware of CP-8851-3PCC from MPP to Enterprise (3PCC to CUCM)?
Thanks for your inputs
10-23-2018 08:51 AM
Hi Adrian.
Conversion from MPP to Enterprise or Enterprise to MPP is not supported.
Thanks.
10-23-2018 09:16 AM
10-23-2018 09:22 AM
That's right. There was an option in one of the older versions.
Right now it is not supported.
Thanks.
10-23-2018 01:03 PM
10-23-2018 01:22 PM
There is no official way to register CP-8851-3PCC on CUCM. You will have to replace them with appropriate models supported on CUCM. Anything with 3PCC is not supported to work on CUCM.
Thanks.
10-23-2018 02:33 PM
10-23-2018 02:48 PM
There is no supported firmware on which we can convert the phone from MPP->Enterprise or vice versa.
Thanks.
10-23-2018 03:53 PM
