Cisco Phone does not boot
j4support
I have two 7945 where the screen blinks breifly then the headset, mute and speaker buttons each come on and off.  This is repeated twice then nothing happens for about 10 seconds and it repeats.
If you want to see what it looks like: http://youtu.be/1Yx6FyXxsjQ
Gordon Ross
Level 9
Level 9
Have you tried doing a firmware reset? Power-off the phone, and press and Hold the "#" key. Once the MWI light flashes, release the "#" key and dial 123456789*0#
GTG
Please rate all helpful posts.
Found out the problem is with the switch.  My 7940's work on that switch fine.  I moved the phone to another switch and now it powers up.
