Dial peers for faxing
ursshared
Level 4
Level 4
I am setting up a fax system.  A PRI will come into a router which will connect to a rightfax server via sip.  I have a DID range on the rightfax server of let say (385) 555-xxxx.  So do I need a voip peer and a pots peer to get the calls from the PSTN to the voip server?  Can I use generic peers or do I have to matched explicitly.  any help would be appreciated.
Terry Cheema
Yes you should set up pots dial peer to atch inbound call and a voip dial-peer for outbound calls to your sip server.
Default dial-peers have a lot of limitations and the config on default dial perrs can not be changed.
Refer to this doc:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html#intro
-Terry
Please rate all helpful posts and amtk the thread answered if you have no other queries
Terry Cheema
Refer to this doc:
-Terry
